Voila le retour de la commande iwlist
[quote]pi@raspberrypi ~ $ sudo iwlist wlan0 scanning
wlan0 Interface doesn’t support scanning : Network is down
[/quote]
Sinon voici quelques autres résultats :
[quote]pi@raspberrypi ~ $ lsusb
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 004: ID 0eef:0005 D-WAV Scientific Co., Ltd
Bus 001 Device 005: ID 1997:2433
Bus 001 Device 006: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
pi@raspberrypi ~ $ sudo ifconfig wlan0 up
SIOCSIFFLAGS: Aucun fichier ou dossier de ce type
pi@raspberrypi ~ $ ifconfig -a
eth0 Link encap:Ethernet HWaddr b8:27:eb:33:fe:76
inet adr:192.168.1.24 Bcast:192.168.1.255 Masque:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:248 errors:0 dropped:14 overruns:0 frame:0
TX packets:140 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 lg file transmission:1000
RX bytes:20015 (19.5 KiB) TX bytes:20195 (19.7 KiB)
lo Link encap:Boucle locale
inet adr:127.0.0.1 Masque:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:72 errors:0 dropped:0 overruns:0 frame:0
TX packets:72 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 lg file transmission:0
RX bytes:6288 (6.1 KiB) TX bytes:6288 (6.1 KiB)
wlan0 Link encap:Ethernet HWaddr 00:13:ef:30:05:12
BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
pi@raspberrypi ~ $ iwconfig
wlan0 IEEE 802.11bgn ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=0 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:off
lo no wireless extensions.
eth0 no wireless extensions.
pi@raspberrypi ~ $ dmesg
[ 1913.202689] rt2800usb 1-1.4:1.0: Direct firmware load for rt2870.bin failed with error -2
[ 1913.202706] ieee80211 phy0: rt2x00lib_request_firmware: Error - Failed to request Firmware
[ 1914.203944] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file ‘rt2870.bin’
[/quote]
En fait, dmesg me retourne des dizaines et des dizaines de fois la même erreur.
J’ai aussi tenté de réinstaller le package RT2870, sans résultat:
[quote]pi@raspberrypi ~ $ sudo apt-get install firmware-ralink
Lecture des listes de paquets… Fait
Construction de l’arbre des dépendances
Lecture des informations d’état… Fait
firmware-ralink est déjà la plus récente version disponible.
0 mis à jour, 0 nouvellement installés, 0 à enlever et 27 non mis à jour.
[/quote]
