j’ai essayer d’installer la piratebox box avec la clé WIFI présentée dans le tuto.
je ne vois aucun réseaux wifi Piratebox … snif
voici ce que me dis mon Rpi2 au démarrage de piratebox :
pi@raspberrypi:~ $ sudo /etc/init.d/piratebox start
/etc/init.d/piratebox: 57: /etc/init.d/piratebox: [[: not found
Starting initialize PirateBox Part2…
ln: failed to create symbolic link ‘/opt/piratebox/www/board/board’: File exists
ln: failed to create symbolic link ‘/opt/piratebox/www/Shared/Shared’: File exis ts
[….] Starting script piratebox :
Generating hosts file ….
Generating dnsmasq.conf ……
Generating Environment-config for ligttpd ……
Empty tmp folder
rm: cannot remove ‘/opt/piratebox/tmp/’: Is a directory
Copy over design files
/opt/piratebox/bin/distribute_files.sh: 41: [: all: unexpected operator
Distribute all into /opt/piratebox/share/Shared
cp: cannot stat ‘all’: No such file or directory
[ ok ] Starting hostap… :.
[….] Setting up wlan:Bringing up wifi interface wlan0
Setting up wlan0
[ ok ] Starting dnsmasq… :.
[ ok ] Starting droopy…:.
Generated HTML-Shoutbox File.
chmod: cannot access ‘ug+rw’: No such file or directory
[….] Starting lighttpd…:2016-04-28 17:54:29: (network.c.409) can’t bind to port: 80 Address already in use
(warning).
(warning).
ça indique que y a déjà un serveur web qui tourne
que retourne
sudo netstat -tanpu | grep *.*.*.*:80
mais y a quelques autres erreurs, n’utilisant pas ce script je ne saurais exactement si c’est bloquant ou pas
